Mental ray backwards compatibility issues with 6.5
I’ve helped a few people w/ this recently, and didn’t see anything about it on the board.
If you’ve upgraded to Maya 6.5, due to the new satellite rendering, the mental ray portion of the license is no longer backwards compatible. The Maya feature is still backwards compatible.
However you can copy the mental ray feature from your old license over ( MayaMRFMf ), and since it is a different feature, it is not superceded by the new mental ray ( MayaMRFMCompletef )and flexlm allows it to run.
So the bottom of your license looks something like this:
FEATURE MayaMRFMCompletef sgiawd 6.500
permanent 1 123456789012
FEATURE MayaMRFMf sgiawd 6.000 permanent 1
123456789012
If you have purchased a new 6.5 license but need backwards compatibility, if you have an attentive reseller they can probably help you get a 6.0 license also for your machine to extract the MayaMRFMf feature from.
