Mental Ray for Maya Pops
Hi all,
This is the problem. I have this simple test scene: a bitmap file textured poly plane lighted by a spot. The camera moves gently through 50 frames.
If I render this with Maya native renderer everything looks nice. (Production Quality settings)
If I render this with Mental Ray, i have this pops and sizzles all over the plane. I have tried the “Derive from Maya” rendering settings which look really ugly. Then I tried like everything, and the only thing that solves the problem is raising the Sampling Quality min and max samples to 3 (in Mental Ray Globals)…which is really time consuming for such a simple scene. (No bump, no displacement, no GI, no FG)
I kept looking for the source of the problem…In the last test I made I put the repeat U,V of the texture 2d placement node down to 1, and everything looked nice (it was at 8 before). So I discovered that the problem appears when I repeat the texture above 1,1 (the higher value the more noticeable problem)
So finally the problem seems to be related to the repetitions in the bitmap file texture nodes…maybe the filtering?..i tried raising the filtering mode and it was no use…
Thanks in advance, Daniel
