mental ray/OSX
hi everybody !
I have a license problem intalling mental ray for mac OSX.
at loading it in maya plug-in manager I have an alert message saying I have no valid license to load mayatomr.lib. the plug load is not possible.
thanks a lot for your help.
Make sure that you have installed it in the correct place. Did you follow the pdf of Mray's installation procedure for Mac's?
Also, make sure that you have the minimum requirements for Mray. It installed perfect on my system, but I also followed the installation procedure exactly. Anyway, check A|W's website and see about downloading the pdf.
http://www.aliaswavefront.com/en/products/...mentalray.shtml
hi WC Hamlet, I just saw the mental ray installing PDF... I have not a network card... do u think it may be the cause of the problem ?
what's your configuration ? Mhz, system etc...
thanks for all.
Hmm... interesting. That might be the problem. Email AliasWavefront and see if there is any other way to get a valid liscense other than using the ethernet card.
My Configuration is
DP 1Ghz G4
768 MB SDRAM
80 GB HD
Geforce 4MX with 64 MB RAM Dual monitor setup
OS 10.2 (I see no need to upgrade to 10.2.3 because it works fine as is)
Maya 4.5
Hope this helps.
Chad
