whats the main difference between : maya motion vectors (via maya software) - MR motion vectors (via render passes) - MIP motion vectors (via production shaders)? Does any method support moving fluids or can blur reflections?
whats the correct workflow of rendering motion vectors in MR via render passes and using RSMV (real smart motion vectors) or other plugins for after effects? is there anything particular i should know?
when composting the frames of a scene that contains a fast moving object or camera, the final movie (not playblast) is always clunky and not fluid. The only solution i found is to use the "animation" QuickTime codec because all the others even the JPEGs and H264 gave clunky movies, but even the animation codec (witch gives big files) was not perfectly fluid and is not very practical. here u can see an example (car sliding in the desert ), any ideas?
how can i optain this type of bokeh effect? tried it in MR4Maya but even if i boosted the bokeh effect ( map) it gave very grainy results (even with high samples) and its not near the result in max?
how can i obtain a lens flare and glow effect for my mental ray sun? the fx glow effect dont apply to the maya directional light and is only supported in the maya software?
how can i genrate a z depth pass that takes everything into account even fluids? what the best way in MR4Maya? and how can i add haze in post if i have a clean zdepth pass?
how can i generate a chromatic aberration effect in post without having to shift the RGB channels and have those empty lines at the frame boundary?
how do i composite my contribution maps? witch layering mode should i choose?
how can someone use an hdr in a scene where a car is moving from point a to point b? wouldnt the static hdr give weird results? whats the most practical way to stay convincing?
in the fast sss shader, why does the shader comes out black if diffuse color (not weight) is set to black, i only want to see the front and back sss?
