I’m facing a new and disturbing problem. Rendering an architectural scene with detailed polygonal geometry MR Standalone (Exported from Maya 7.0) 3.4.6.9 constantly crashes even in lower resolutions with:
Hard to know what is wrong.. how much memory is being used by the mayabatch when it cops the error? Does it give this error if you just render everything with a default lambert shader? Could be a geometry error.. run polygon cleanup or try removing large sections of geo to isolate the bad piece.
I’ will now try cleanup and lambert - only shader.
BUT - the error is not produced by Maya batch. I export to .mi and render on MR Standalone on a different machine!
BTW. Both machines run different versions of MR. The workstation runs the default version, shipped with Maya 7.0. On the renderbox runs MR 3.4.6.9 - does that matter?
QUOTE(sholari @ 04/25/07, 10:32 AM) [snapback]264817[/snapback]
Yes, but also you need to link the mr libraries of your maya in also.
