MentalRay for Maya : Contour & batch rendering
Hi,
I found a nice tutorial for cartoon shading :
http://www.fenriz.org/projects/maya/maya\_toon\_shading\_i.php
but there's a problem :
when I render the current frame, the contour are rendered, but when I do a batch render of my scene, there's no more contours !!!
can someone help me ??
thanks
Hi, nice tutorial.
I had the same problem with batch rendering... Then I realized that within Maya the batch render worked fine.
As I was working late and getting a little bit tired I ended finding out after a few minutes that my MayaNetRender and Smedge where set to render with the default Maya render instead of MentalRay. I just switched and everything is now fine.
Maybe it can help you... goodnight :slight_smile:
