Imre Tuske has written a MentalRay translator for Maya, seems like it works great. But it is not available for public yet. Hope he will do so soon.....
see note on: http://www.cgchannel.com
Makes me sad once again to discover all the shortcommings of the maya renderer (motion blur, speed, ram et al)
I am still waiting AW/MI translator thow.
it's lookin real good... can't wait...
it looks great, but im not sure if its ever going to be made public. If you read it the guy does not give much away, and menal ray is going to be avalable for maya in the next few months anyway. but id still love to get my hands on raytools!
Mental Ray must be great, but heard that it is damned slow. Much slower than the maya renderer. Is this true?
Not sure but I think everything is quicker that MAYA renderere
Yes, because mental ray is a raytracer. If you wnat faster rendering get renderman, but then you wont have raytracing...
Maya renderer isnt that bad however its quite fast when you know what you are doing. Its just that people seem to want a snap my gingers and everythings ready type trenderer. But if we ever get such a renderer we are all going to be out of a job, in notime.
Speed of mental ray depends on user settings. It is has awsome quality.Its fast or slow depending on you just like maya renderer. I hope no one expects super quality from push button anything. Defaults in anysoftware rarely give the best resaults. Learn your tool and use it well, the outcome will always be good. That said I would love to see mental ray for maya.I have used it since softimage 3.x days into xsi and would love to finnish my work with that mental touch now in maya environment...
"I put my faith in the power of my own mind."
ICQ#58898276
metnal ray is not a raytracer in xsi, and i seriously doubt the standalone is strictly a raytracer as well.
according to the documentation in xsi, metnal ray is a hybrid renderer, rendering in scanline by default, and only raytracing objects that need raytracing.
someone may wish to double check and confirm or deny this.
as scanline rendering goes, i would imagine that it is highly optimized, and as stated above, would prove very fast given the correct settings.
any experienced mental ray users care to chime in on the scanline quality/speed ratio?
Edited by mr.bean on 09/03/01 09:03:07 AM.
1.1. Algorithms and architecture
automatic fast scanline rendering
optional OpenGL accelerated rendering
ray tracing, used automatically and transparently where necessary for refraction, reflection, raytraced shadows, etc.
two alternate ray tracing acceleration methods: BSP and regular grids
contour rendering: cartoon animation, fine control over contour placement, overlaps, width, color, transparency, and other user-definable criteria
incremental changes: when rendering an animation, it is sufficient to define the differences from one frame to the next, instead of redefining the entire scene for every frame. Intermediate frame data that is not changed, such as tessellations, is cached.
1.2. Sampling quality
adaptive recursive oversampling (multiple samples per pixel until a contrast quality criterion is met)
adaptive recursive undersampling (fewer than one sample per pixel taken initially)
automatic anti-aliasing of all features such as transparency, refractions, reflections, shadows, area lights, textures, caustics and volume caustics, and global illumination and multiple volume scattering
edge following (if over/undersampling misses a feature, mental ray detects edges and adaptively follows and renders it to avoid intermittent gaps and roping'')
low-discrepancy jittering to avoid staircasing'' at sharp edges
dithering avoids color banding due to limited output image color resolution
full Quasi Monte Carlo low-discrepancy sampling avoids random noise'' and ensures faster convergence to the correct solution. Algorithms are completely deterministic (no animation flickering due to randomness; re-rendering a frame produces exactly the same result).
1.3. Texturing
textures are interpolated and anti-aliased adaptively at rendering time without requiring manual intervention or adjustment before rendering begins
reflection maps for fast and simple distant environments such as sky cloud images
nonlinear texture projection
pyramid textures (a generalization of mip-map textures for fast and smooth texture interpolation)
memory-mapped textures and memory-mapped pyramid textures (only the pieces of the texture that are actually required are loaded/unloaded on demand from disk to memory)
1.4. Shadows
area lights create shadows with variable and accurate softness: spheres, discs, rectangles, and cylinders (flourescent lights); no fixed manual blurring of shadow maps required
raytraced shadows for correct shadows, including transparency effects such as colored shadows cast by stained glass
shadow maps for fast and simple shadows and soft shadows for those light sources where the accuracy of raytraced shadows and area light sources is not required
all shadows are visible in reflections and refractions
self-shadowing: objects automatically cast shadows on themselves as well as other objects
1.5. Volume rendering
volume shaders implement nongeometric volume effects such as fire or smoke, in both scanline and full raytracing modes
ray marching (sampling space iteratively or recursively, for example to render visible light cones)
volumes cast shadows (for example, smoke that casts an accurate shadow)
volume self-shadowing
1.6. Motion and depth blurring
accurate motion blur by distributed ray tracing
object motion blur
vertex motion blur
motion blur is visible in reflections and refractions
motion-blurred light sources that generate blurred highlights
shadows of moving objects or lights are correctly motion-blurred
depth of field
collects motion and depth information for alternative postprocessing motion blur and/or depth of field
1.7. Global Illumination
global illumination permits physically correct light simulation, which combines forward and backward ray tracing to simulate all possible light paths and light interaction from light sources to the camera, including indirect lighting, light focusing, translucency, glossy reflectors, and radiosity, without the need to manually prepare and combine each effect separately
caustics (light patterns caused by refraction or reflection of light, such as bright spots caused by lenses or bottles, and underwater light patterns)
algorithms for global illumination and caustic simulation is independent of geometric scene complexity
volume caustics: focused light made visible as a beam in fog or other diffuse media in volumes
multiple volume scattering: light interreflecting diffusely in fog or other media, such as the backscattering glare of headlights in fog, or light transport in clouds, or halos around bright light sources in fog
1.8. Frame buffers
In addition to the standard rendered color image, mental ray supports up to 12 frame buffers recording various data about each pixel:
RGBA (4*8, 4*16, or 4*32 (float) bits per pixel)
depth
motion vectors
normal vectors
labels (of objects by default; under shader control)
shader maps for incremental preview rendering
user-defined: eight frame buffers with selectable types: RGB, RGBA (8/16/32 bits per component), alpha, intensity, depth (scalar), integer, vector, bit, compressed basis vectors
1.9. Image file formats
There are 36 built-in image file formats with automatic content-based type and subtype recognition and conversion when reading:
Wavefront RLA and RLB
Softimage PIC and Zpic
Alias image
Dassault Syst
its not that I am searching for "the do me a perfect render button" no, I like tweaking the sliders and experimenting with them, if I wanna have a quick render I can go with cinema4d ...no I have a animation wich renders 3h 30 min. a frame (maya4) and I need 7000 frames !!!!hehe and I dont wanna wait 2 years. Ok I have 4 dual ghz machines but that seems not to be enough...so if anybody has a renderer which is, lets say 10 times faster.....drop me a message. (Renderdrive does not help too - I have one)
@@1.1. Algorithms and architecture
This feature list is for mental ray v2.x, not 3.0. A number of things have changed.
Mental ray is a hybrid renderer utilizing both scanline and raytracing techniques as needed. The user has full control over whether the renderer uses either or both of these methods as well as a number of other things. With mr v3.0, the renderer's core architecture was practically rebuilt, so any of your experiences with mental ray in terms of long renders, wasted memory consumption, and other misfortunes are now tossed out the window. v3.0 is a radical improvement.
If your scene is that slow then i guess you will need a renderfarm to do the job.
yeah... I calculatet that a 64 cpu origin Server would render 14 Days!! So I put that one to my christmas wishlist. Hope my parents will give it to me
Or maybe you should try splitting you scene in to managable chinks and then compositing them back together, most things in the scene mahy not need to be rendered and for those that are, the primary visability radio button is a life saver..
bj
