hello,
i try to understand how the node Merge Expression works.does anyone knows ?i thougth the expression are calculated with the A input channels, and the result is copied to the B input.but it does'nt work as simply...
thanks
auD.
i had the solution, Ar, Ag, Aa ... means the red, green, or alpha channel of input A, Bg, Br, Bb... is the green, red, or blue channel of the input B
actually quite simple....
yep, that's all there is to it, plus you can reference x and y positions which is very handy.here is a simple example of a horizontal wipe using the MergeExpression node:
MergeExpression { inputs 2 expr0 x>split?Ar:Br expr1 x>split?Ag:Bg expr2 x>split?Ab:Bb channel3 alpha expr3 x>split?Aa:Ba name MergeExpression1 label wipe selected true xpos -320 ypos -40 addUserKnob {20 User} addUserKnob {7 split R 0 480} split 170}
