Mesa3D/Xfree4.2.x
Hello all,
I am trying to upgrade Mesa3D on my linux box, but because of the dependencies of X that came with RH7.2, I cannot do the upgrade. I tried to download the X files to upgrade it but I am not too sure as to what way is best: upgrading X on top of the current one, and upgrade Mesa at the same time, or uninstalling X (the one that came with RH) as well as the old Mesa, and do a clean install. Im just a little afraid of screwing things up. I did it twice in the past and I only got it to work once… So is there a “best way” to do so?
what are the conflicts? there’s a good chance you need to solve them regardless of whether you install from RH packages or compile the code yourself.
Same problem here! I have successfully installed RHat 7.1 on my system and downloaded the fixes/upgrades form the RHat site for 7.1 for the following:
Xfree and Mesa but it seems I can’t install the Mesa files w/o installing first the Xfree,but I can’t install the lib file because IT requires libc.so 6(GLIBC_2.23)!!! Is this some programmers idea of HELL!!!A dog chasing its tail Man!!! How do you get around this? Should I just download purchase a RedHat 7.2 CD. Or is 7.1 a safer bet to install Maya 4.01 Linux?
Confused in California!!!
Hello
It seems to me that using Red Hat 7.2 might be a safer bet. However I would not
update to XFree86 4.2.0 until I get a Red Hat rpm, and since graphics drivers
can be sensitive to XFree versions, I think I’ll wait for drivers that are testsed
under XFree86 4.2.0
The version of Mesa I run under Red Hat 7.2 is “Mesa-3.4.2-10”.
I assume that you are trying to get Mesa 4 to work.
regards
Argyris
you could just go ahead and upgrade to Debian Linux. No more dependancy headaches EVER.
shrug
