I’ll admit it – I work in a sloppy, haphazard manner. As my scenes get bigger, my outliner becomes really ugly looking, and it gets to be a chore to find anything.
Is there a way to move items around, or otherwise organize the way things are listed in the outliner? Dragging and dropping seems to want to “nest” things – create hierarchical relationships that are not necessary, and can bung things up later.
Yes you arent paying attention to visual clues here!
Outliner can in fact do both nesting and just moving around. Se the ouliner shows you what it thinks you are intending. Whan you era middlemouse moving you will nolice a line apperas where ever you move. Now if theres just on line it thinks you want to drop it there, between the nodes. If its TWO lines it thinks you want to parent it!
NOw sometimes its hard to se if its two or 1 line if you move the node a short distance (because its hard to discern near the highlight), then jut pay extra hard attention or just move it furher and back.
IF this becomes terious use the reorder mal command… It can be usefull to have hotkys for moving them around (eg having “reorder -relative 1 ls -sl;” bound to say shift down arrow whan the outliner is active for example)
Other things to know is to utilize the filters. And also the “f” (focus) key will dig out whatecver node you have selected and find it for you in outliner, a bit like in the viewports.
