[size=5]
Hi,
I have a problem with getting the tangent vector on a curve in Maya using the Maya API. I have a point on the curve for which I get the param value using :
lStatus = lCurveFn.getParamAtPoint( lPointonCurve, lParam, lSpace );
This returns MStatus::kSuccess. lPointonCurve is the first point on the curve found out a distance of 0 from the curve's start.
I then try to get the tangent of that point by calling :
lTangent = lCurveFn.tangent(lParam, MSpace::kWorld, &lStatus );
This also returns MStatus::kSuccess.
But the tangent vector is nearly null ( 0, 0, 6 * 10 ^-13). I can't quite understand why that is.
That code seems to work on simple splines but not on the curves generated by our internal tools. I can't spot anything obvious that would make it break though.
Any ideas ?
Thanks,
Pascal.
