Misss_fast_skin_maya Reflection Problems
Hi all,
I am trying to get blurred reflections using the misss_fast_skin_maya shader, but am having no luck. Presumably the "Reflect Shininess" value is supposed to control this, but those values seem to have no effect, as I always get chrome-like reflections (I've tried values from -5000 to 0 to 5000). I have no problem getting dgs_material blurred reflections to work, and maya shaders with mental ray "Reflection Blur" work as well. I did a bit of snooping online and found a few cases of people also complaining about this problem, but have found no solutions. I'm running Maya 8.5.
Anyone else run into this problem? Any ideas how to fix it?
Thanks!
The Gnomon tutorial on SSS talks about using layered shaders to get around problems with reflectivity. It works pretty well, and you can use this technique to get more control of various attributes. You can't use a standard Maya layered shader with the Mental Ray shaders, but there is a download available from Pixero that works. It's called "Mix20"
http://www.pixero.com/downloads\_mr.html
