Modelling a fat bird feather
i need to model a cartoon like feather for a bird (i want it kinda resembling a leaf). i've got good results both with the look and deformation, just by doing a closed loft around 6-8 curves.
however the tricky part: i want "cuts" in the feather (not realistic, only about 3 or 4 to keep it stylized.) i thought of just trimming cuts into a feather-shaped plane, but that totally removes "fat" look i'm after. i can't really use transparent texturing for the cuts, because the feather has depth and this might give rendering artifacts if you can see the other side.... well after typing all this i've just answered my own question godammit!!! ... if i use transparency for the cuts but make sure the feather is single sided then there should be no artifacts 'cause u wouldn't see the back of the feather.. man i suck.
oh well if anyone has any other comments that involve just modelling a solution i'd still be keen to hear them.
Seems to me that you could do this with polygons much more easily and then use artisan to smooth the edges.. The important thing is that you merge the edges.
or then patch the edge insert an isoparam and detach then move the other end a bit (remember to add the isoparam in the adjoining surfs too and rebuild from 0 to spans or 0 to 1)... but might be overkill.
