More Bugs with Mental Ray
Hey y'all
When i install mental ray for maya, it will work sometimes and other times, when i click on the rendering drop down, nothing appears, and i get this error
Error: Cannot find procedure "MayaWindow|mainRenderMenu".
When i uninstall mental ray the render menu comes back.
Any suggestions?
How much ram does your system have?
It ain't my Ram, i have 1.5 GB
It also happened to a friend of mine on his laptop, so im pretty sure it's not my computer
I noticed the same problem once - disappearing render menu. The bug seems to have saved into one of my scenes, each time I open it, no menu - only for that scene though.
If you just do a render it should bring the menu back, works for me anyway.
I have the same problem. If you toggle back and forth the renderer type (between maya and mr), it goes away, and you can render normally. YOu have to do it every time you open maya. definitely a bug.
-MD
Same problem here also.
yes, render once and the menu will get back
