I dont know if this has changed recently (cos i accidentally pressed something) but the manipulator only appears on the pers view. This means if i want to rotate/move/scale something in the side view i have to use the pers view. Is this the defult in maya or have i changed something?
that only makes the manipulator in the pers view bigger. In the other three views, the manipulator doesnt even appear or is greyed out depending on if its the move/scale/rotate.
We had the same problem. It turned out to be the monitor being set to 16 bit colour quality rather than 32 bit. Our monitors are tft's. Right click on the desktop - properties - settings. It'll be under there. Hope this helps.
hmm i will try that but i suspect my monitor display is already on 32bit.
I dont know if this will help or add further confusion but i recently noticed that if i load a scene striaght from explorer (which then boots up maya) i dont have this problem. It is only when i have already loaded up maya and then open a recent scene that i get this problem. I have had problems with my project set up so i dont know whether this has anything to do with it.
