MR and Architecture Animation
hi all
i’m about to undertake another project that could involve using mental ray for an architecture presentation.
for architecture and building fly-throughs, what is the best modelling method that will result in the least amount of problems when rendering later with MR. ie: should the walls and objects be made from polygons, nurbs, all double sided etc. if polys should the building be one piece or is poly planes stacked together ok… and any miscellaneous things that could cause problems with MR.
last time i used mental ray for animation i had some problems with artifacts, and if there was even a really tiny gap in geometry, for example in a corner-wall join, it would result in very unpredictable lighting in the rest of the building - quite weird really.
still have much to learn with MR but any tips greatly appreciated.
cheerz
-paul
I have found that it is best to minimize the numer of objects being translated to MR from maya. This includes converting anything that does not need to be nurbs to polys and combining poly models and it’s peices that do not need to animated individually.
thank’s - other problems we ran into were with baking textures and lights into surfaces, the results were sometimes quite unpredictable and occasionally just plain wrong… i havn’t been able to find any websites that give tips on baking or things to watch out for with MR for maya.
rendering MR animation without baking not ideal because the renders would just take forever… so hopefully i will do some more test bake scenes and they will work out ok..
oh one other thing - when u say combining poly models… so for example with architecture modelling would it be best to have the roof and the walls as a one-piece polygon object…? wouldn’t that mean i would have to assign different shaders to different faces…? i thought MR cannot render surfaces that way… but then again i could be thinking about something else
thanks again for the feedback so far.
I have not had problem with MR and objects that are combined with multiple shaders.. but a polymesh were all the faces are merged and you have different shaders assigned can cause problems.
ok - so basically using the Polygons > Combine command is ok once shaders have been assigned…
one last question by “merged” do you mean an object that started out as a single mesh (like a sphere assigned multiple shaders), or do you mean multiple objects that were combined and then had edges merged etc…?
cheerz
-paul
You have to combine objects before you can merge their edges.. combine is more like a group ..for example you can seelct the shell of individual object sin a combined mesh whereas merged objects are one shell
yep that’s cool - i guess what i was asking is will merging their edges after combining objects cause any problems…
thanks
-paul
Possibly it will.
cool thanks for all your help
incidentally - i just did a test with baking a simple poly sphere (maya 4.5) with texture and shadows, the texture after the bake is ok but rotated about 3 degrees for some reason…
