I’m using the New bake to vertex function under the Mental ray for maya connection. The baked colored vertex have RGB values higher than 1, super colors.
I try to clamp them in the options in baking, but those options don’t seem to clamp anything, If I try clamp between Min =0 Max =1 I get blown white vertex colors for entire mesh. all at RGB 1.
Anyone know about this? Or Maybe I’m a newbie
By turning on clamp max, anything greater than 1 will be clamped to 1, resulting all white.
You’d better find out why vertex colors are higher than 1 in the first place.
cut down photon energey, etc.
-jasmine
later on I wrote a script that clamp down the vertex colors, which worked and the colors looks the same as before.
What seems odd is Mray clamp all vertex color to white, even those below 1.
yes the high energy makes them over 1, how ever it looks the same when clamped.
