mostly got the hang of MR in maya, but one nagging problem: How do I limit/ reduce unrealistic color bleed from the final gather rays? For example if a building is surrounded by grass, the entire thing turns pale green from final gather. And this is not a GI problem(!), my GI is turned off and can of course be controlled by 'photon attributes,' etc.
I am rendering a exterior scene with MR physical sky and using the mia_material with basic settings similar to lambertine shader, only final gather is on in MR settings.
Any help/ advice would be greatly appreciated!! There must be others out there battling this problem!
THANKS!
A
you can adjust the intensity of your grass (and sky sky should be brighter than jsut the color you see, because it IS a darker shade of more intense blue, which just bleeds into other sensors in our eyes). Or the fg contribution (theres a global one and a per shader one).
Just so you know: unless your actually converting ALL your color settings down by gamma curve and then gammaing up the result then you get a nonlinear error on your image. Which causes all kinds of problems, its okay wehn all is local but when you add global lightning (fg and gi), your getting all the secondary rays at wrong intensity.
joojaa- thank you for your help!!
I think that you are right about the gamma problem messing up my colors! as you know, there is a mia_exposure_simple attached to the mr physical sky by default, but I have not attached any gamma control to my "architectural material" (mia_material). Where would I attach it, and what value for gamma is appropriate? Will the pers. camera also need gamma control? or is that taken care of by the physical sky?
sorry for all of the questions!! thank you very much!
A
very nice- thank you for the link!
