MR-maya 501 batch bake issue?
Ok what am I missing here.
I have set min max values for the final gather in the render globals. Because i know a texture render wont generate good automatic values for theese. Now ive cranked them pretty freaking low... Meaning it takes aeons to render (thats cool it can if it takes 4 hours to render the files and then every 100 frames takes 10 in its ok).
But, the freaking surfaces have all manner of render issues on them. like leaking raytraced shadows etc etc. And the fg solution sucks! Even tough the same settings in maya 4.5 produce superb quality output at faster values (yeah did i mention i was using 5.01), and i wouldnt want to migrate back!
What the hell am i missing! Its as if mr woudnt respect the settings... or well it seems to reflect this in rendertimes, noty quality of output.
Anyway if no one can help then i must ahem go back to using 4.5 instead (wich seems kindof stupid).
PS. while your at it is there any way to overcome the fact that namespaces get Illegel names for the filesystem.
I have had the same exact problem. I've pretty much given up on FG for animation. The bake process takes too long to be worth it, granted that it works at all. I don't know how heave of a scene you are using, but mine are I'd say between medium and low.
Have you tried the Dirtmap shader? It's not FG but it's faster and the best part of all is; if you are baking textures the settings are the same as they would be if you rendered it out per frame. It still takes a pretty long time to bake however and I'm in the process of finding a way to get it to work.
Baked with 4.5 and got better ersults with 1/10 of the rendertimes!
