I am hoping to use other mahcines on our network to help with large batch renders. The machines have Maya installed but not MR standalone.
I can't find any info on using MR to do this in the help files. It just says you must have MR Stand alone.
From other posts I get the impression you can distribute a batch accross a network only using Maya unltd but only if you are NOT trying to distribute the render of individual frames.
Right now we are copying the whole file onto each machine and rendering sets of frames one at a time. Is their a better way?
and is there a way to simply tell another workstation to render my file remotely, without physically getting on the other machine?
Well theres satelite render but thats different. it renders on many machine sthat are as one and yes you get 4 lics of satelites per maya. However satelite rendering has its catches.
Also note thet the way you do it IS in general the best way to go.
Mainly it depends on if you want a cluster render or not, satalite is a cluster, but clusters have their caveat, namely your network must be able to sustain the rate. Wich is why many users have probnlems, no chepao networks for tryuue custers. However clustering has its onw set of drawbacks, such as not all operations are abkele to use it.
QUOTE Right now we are copying the whole file onto each machine and rendering sets of frames one at a time. Is their a better way?
Well in general youd want to use a network drivefor the files!
It sounds like we are going about it the best way then.
As for netwrok drives, i worry about slowing down the network for others who need it for their own, sometimes heavy bandwidth work... won't a workstation rendering lots of bitmaps to a network drive clog the pipeline a bit, and slow down the network for others?
Well thing is a gigabyte ether is many times faster than most harddrive clusters. So if you have a GOOD dedicated disk service then you should be well off. Besides the renderers may cache some of the data anyway. But yes if you ahev aaloto fo assets you will have some ccongestion.
Nobody said rendering is CHEAP.
Edity As a additional advantage most stuff is now much easier to backup! Offcourse you may end up moving about some critical stuff to local disk if realy needed, it all depends on whatkind of dispatching you use.
