MR physical light only designed for dgs
i just learned from mental images that the MR physical light
shader is only supposed to be used with the DGS and dielectric
materials and does not work properly with other shaders
As usual, not a single word in the maya’s documentation neither in
training materials from 3rd parties. So since everybody moved to the
mia_material this shader is completly usless wich is too bad because it
was supposed to let users to get physical or photorealistic resluts.
Ive tried to tell you that your hunt for physically correct is not really fruitful.
You would need to abandon most concepts you hold true to get further, theres no rgb color in reality, no gamma correction no nothing. You would nee dto start picking colors in lab space and convert those to physical photonic energies.
So you have now 2 avenues you can take. Concentrate on nice images OR start writing your owm shaders than atleast YOU know whet kind of corners are cut. (his is the reason i dont use Mia_material, atleast with normal shaders i know what the sequence of calculation is, and where it goes worng)
wich is too bad because it was supposed to let users to get physical or photorealistic resluts.
Supposed to? Where does it say so? In actually you should be using the mib_light_photometric shader with light profiles form the light manufacturer.
All the manual says about the correcness is that it models the right decay for a ideal light (note a ideal something is NOT physically correct, its correct as in according to the known physics formulas, which may or may not be correct but certainly hit right ballpark). Its not any more correct than a maya light with quadratic decay (this can be verified by experimantation and reading code). The name is unfortunate its not more physically correct because its name is physically correct. Its just physically correct if you plug the right values into it. As is maya light set to quaratic decay and right intensity and color. Theres no magic we fix your input going on if your measurements / assumptiosn are worng so will your scenes.
Thing is all shaders work in pairs so everything developped at time of the dgs materials is made for dgs materials everything after that is not. So Shaders only work in tandem with the saders thay are designed to work with. You can not get physical corectness with a physically right light, unless your shader is physically correct too and paired with the lights code. The DGS shader is not actually 100% physically correct either even it cuts corners, and even so is applicable for only a smalls set of surfaces.
But then even this is not enough, the problem lies in your eyes, even if you did physically correct it would still need to be whitebalanced and treated physcially uncorrectly to meet your eye. Since the display does not have the actual range of your solution but a set slice of it. Now this conversion would need to mimic how our eye works! This unfortunately IS NOT KNOWN AT THIS TIME. And yet it is implemented in lot of cameras differently. So does that mean a digital camera is off? Yes definitely. However photorealism means to act like a camera, well which camera is it you are after? Each of them produce slightly different things. Technically you could make a raw file out of the physically approximate set of solutions and then convert this raw with the cameras converter for example in adobe raw. But but… Every image is often corrected by a human to get most of it so most pictures you see are NOT PHOTOGRAPHICALLY CORRECT just nice.
All shaders are tradeoffs between right and wrong, tha Mia_material is not very special in its physical correctness. In fact i would say its less correct than other shaders I have used. Its just a nice package. For example the definite clue to this fact is that it has a ambient occlusion term. You know what, reality has no ambient occlusion, amibent occlusion is a trick. Its just correct enough, as is a lot of other things. So you would need to abandon the Mia_amaterial as well.
IN FACT: There’s no such thing a a physically correct render. All of them are partially physically incorrect. To be physcally correct would mean so much computation on your part that its insane. all your textures would need to be repainted into spectically correct values etc. Which would basically mean youd need a new sort of camera and a new 2d painting application. You would also need to test the material at different agles to get the right kind of physical correctness. You would need also to use the spectrographic render mode. Even so you would go wrong.
So you ARE as a base fact doing some approximations at onset just the degree of the approximation is up to you. You can do better, but you can never unfortunately get it right. Because its just not possible as far as we know. But yes please show this wrong, you will get a Nobel prize in physics no questions asked.
PS: you should really start reading the shader code mentalray ships, and then enroll to university physics course on optics and a lboratory exercice on it and you will soon see that no simple shader can be 100% of the way. You can get 70-90% with coarse approximations.
i will use mia and physical light shaders since physical accuracy is not achieveable anyways and it’s all about aproximation.
thanks for the info and congradualtions for your daughter!
