Mray displacement on poly surface
wath's wrong with mray displacement map?
wen i use a file texture to drive the displace on a nurbrs surface it works fine, perfect!!
bu with poly surface, the mray progress windows ( from renderglobals) wen render say tat mray is reading the file textures and them it stop!!!!! the maya stop work and freesy
i alread tried diferents files formats ( tga , tiff , etc..)
all works fine with nurbs , but with poly it dont work, i alread verify the ( diferent setings ) approximation editor and nothing,
iff i use procendurals for displace, it work fines in poly surface, but file textures made in photoshop dont work on poly.
some one have the same prob?
thx for the help
and sorry my bad english
No one has this problem??
thx
No i cant say i do! But, displacing polygons has many problems. It only works correctly if you have allways smooth surface normals. Even then for the calculation power you waste on it youu wold have redered a subd surface instead, at the same cost.
thx for the reply,
i think , use displace with poly is a waste off time,
i make tests with sudv but the results is not good if compared with nubrs,
stay with nurbs is the choise.
Thx for reply!
