MS DX exporter Animation Issue
Hey guys... I think I may have found a bug in the DX libs that the exporters are built from, but I can't be sure. Please note that the issue I am having appears with the RightHemisphere DeepExploration package as well.
In Maya the animation seems fine but in mview.exe (the MS MeshViewer) sometimes the objects "jump" a bit during the animation. It doesn't seem to do it for all animations, but I have a test scene here that it does do it with:
http://www.massivepoint.com/dx/test\_01.ma
and the resulting exported .x file here:
http://www.massivepoint.com/dx/test\_01c.x
Its a tough one to explaine, so please take a look. It almost seems to be a rotation issue, where if an object is rotated in just the wrong way this happens.
To try and fix this, I have written a .mel script that gets the transform matrix from each object in the scene for each keyframe. I then format it for .x. So I figured I would be able to simply cut out the animation data from the exported .x file and replace it with the data that the script genereated.
This works to a degree, but my axes are wrong. Currently I have maya set for Y-Up. What else do I need to do to the matrix data to make it line up correctly?
Sorry for the long post, but if you need more info about something, please ask, I would love to get this issue nailed down.
-jake
