hi
I have just been trying to get the multiplane node to work to simulate parallax between numerous layers in a comp, but am having some issues...
I tracked the live action footage in boujou and loaded the .ma file into the camera in multiplane. I have 3 layers in multiplane which I have offset in z space and resized to fit the frame. Everything looks cool when I step through the comp, but when I try to flipbook or render the shot I am getting some weird jittering on the front two layers. I have checked the camera track and it is all good, so am thinking that this must be some bug in the node? Even when I compare the rendered frame to the file-out in the comp, the rendered frame has a position offset in the multiplane layers that you can't see inside the shake gui...
If anyone has any ideas on whether I am doing something wrong or if this is a bug that would be appreciated.
cheers,
kim
