Multiple Container Maya Fluid Simulation
Anybody has experince with very large fluid simulations?
I am looking for a way to use multiple containers for a single effect.
What you'v got in head ?
it is a bit hard to understand what you want to do
I've used about 20 containers in one scene file once.. So it depends on what you are looking for.
and don't forget that you can have as many emiters in a container that you want.
the only question is : what you want to do ?
A large scene (explosions and a rocket taking off). We will probably have to transmit fluid information between containers via scripting. Got it working for atest already.
are you using dynamic simulation or non dynamic? if you use non dynamic it is very essay to do the same simulation in all containers with different timings on in connection editor.
let me know if u are using non dyanmic, i can try to explain.
i am not sure with dynamic simulation but i am sure u can use the same technic
cheers
please tell me how to render multiple containers. I have six containers in which a jet is exploding but how to render. when i render, it renders only first container.
