MultiPoint Radius
In particle shape node we can give value to multi point radius for whole shape node,but can we give different value to each & every particle..is this possible??
i mean some point will get 2 some will 3 some 2.4...& so on.Reply ASAP.Thank you
add a radiusPP attribute
Bro,i already try this radiusPP on particle shape which has render type to MultiPoint.And i set radiusPP=noise(time); But nothing working here..it's taking value from Multi Radius Attrb under particle render type .
Ok listen .....I want to do this
http://hosok2.com/project/dataExpansion\_2/dataExpansion\_2.html
(adaptive multipoints radius test).
can u tell me how hosuk chang is doing this using MEL(you can check MEL on same site).Reply ASAP.Thank you
_______________________________________________________
With Regards
Ruchit Bhatt
