Well it’s not spectacular but it’s my first. I’m currently stuck on it. For whatever reason I can’t attach a two surfaces with trim lines. And I don’t know how to get rid of them. Also the seam needs to be removed. Well here’s the site fxstudio.home.mindspring.com click on renderings.
The links aren’t working.
Still ain’t working! I can get to the home page, and then into the renderings bit where I get a list of pictures, but those links don’t work. It says ‘File not found’.
Hmm… needs alot more work. If you want to attach the two halves, do an align with an attatch on the front seam, then do a close surface.
For seams you can use the expert;) advice above or you can try playing around with global stitch. For animation or not, you’ll want to thicken the lips. Curve the cvs into the mouth to give it some weight. Sculpt the cvs around the mouth to protrude them a bit. The isoparms around the mouth should probably be reduced/spread unless you’re going to paint weights and animate wrinkles. I can see that he’ll be expressive looking. Excentuate the browridge, that along w/the lips will make him unique.
Frodo
