It takes me about 20 mousewheel clicks forward to zoom in and with one back click, I am all the way zoomed out again. How do I stop the mousewheel from zooming out so much?
well you can sacele the zoom tool under View -> Camera Tools -> Zoom Tool ->
but the problem might alos be how your mouse is configured because my mouse zooms out as much as in.
IN general its better to learn to use the alt- left+midmouse zoom insrtead its more accurate and better on your ligaments in general.
Post deleted by DiggityDanks
That didn't seem to fix it. Is there a way to bind my 4th or 5th mouse button to zoom like you said? It is kind of awkward for me to press alt, left and middle button all at the same time.
alt an rightbutton does the same trick. but alt left middel is easier IMHO sice it goes so well with switching between translate rotate
But you prettymuch need to use alt all the time anyway.
Ps and no they cant be changed they are hardwired!
Thanks, I don't know why I never tried the right mouse button. I don't know what you mean by switching between translate and rotate.
rotate camera around is alt + right mouse and pan is alt + moddlemouse
so because you go over thaem all the time you get used to pushinng on then thge next so you translate over the zoom mode.
Error: Backend Fetch Failure
