Hello. I'm attempting to do the 3D smoking tutorial at http://www.highend3d.com/maya/tutorials/smoking.3d and ran into a problem I cannot seem to solve.
I've got an object which is my cigarette butt.
I've got a path which is the word "Maya" spelled out in cursive.
When I attempt to attach my object to the path, it attaches, but when I animate it, the cigarette flips back and forth between the front and back sides of my path. I want it to stay on one side of my path (the back side).
In the manual it says:
"World Up Object - Specifies the object the world up vector tries to align with if World Up Type is set to Object Up or Object Rotation Up. For example, you could specify the world up object as a locator that you can rotate as needed to prevent any sudden flipping problems as the object moves along the curve."
This speaks somewhat to my problem, so I've tried using the "Obect Up" option, but haven't been successful.
I've tried every combination in the edit box (except for the correct one supposedly), but or reference I'm currently using the following settings:
Follow: Yes
Front Axis: Z
Up Axis: Y
World Up Type: Vector
World Up Vector: 0 1 0
Any help would be appreciated.
