My subdivision head
it will finish when ears are done..
waiting suggestions
well it looks like someone smacked him between the eyes and caused the upped part of his head to cave in… you might wanna grab the whole of his forehead and eyes and pull them forward… but then also skin seems too ridged and teh cheek muscle too over defined if your going for realism… the nostrils are too flared looks really weird.
thanks.. it was my firs try.. i started to extract faces with help two image planes .. the computer was too slow and it is hard to make adaptation to original 2d sketch.
so he has realy big nostrils
You found the missing link!
looks like he needs a face-life and a bit of rhinoplasty. My suggestion would be to study facial proportion and apply it in a correct anatomical way. nevertheless this is quite good for a first model.
Yup, but more seriously, with a bit more of a bulge of the upper and lower area of the lips (orbicularis oris area), and a flatter nose this model would go down really well as an ape of some sort, nothing was mentioned about this model being human :0)
I like it.
thanks for suggestions..and yes right ,i think i would try face-life on his.
before the subdivision, i was work on nurbs patches for head modeling
this is my first subdiv.. i also an amateur sculptor .. subdivision looks like making a sculpt in CAD… and i like this way
Try the Connet Poly Shape script, IMO the workflow using this plugin is superior to mayas inbuilt sub Ds.
The main reasons are that i find it faster easier to texture and that it teaches cleaner modelling than Subd’s.
ahhh…another SubD head
I wouldnt mess with CPS. Go the extra mile and figure out the subDs. Its all in the workflow. A good rule of thumb is u should primarily work in polys then every now and then convert to subDs to see if u like it, then undo and continue polys. Once u get the feel of how polys convert over u can gain the aquired skill of modeling an entire figure in polys then converting when your done. The only slow thing about subDs is when you are in poly proxy mode. Once u go to standard and mess the levels u will notice its extremely fast. Also you can refine your levels which u cant do with CPS. Im at the point where i model completely in polys the convert and add detail where needed.
About your model, it seems you “freehanded” this head, Try using image planes and u will notice not only a quicker workflow, but a head that more resembles a modern day human
Hey I freehand all thet ime what you trying to say?
Actually another quick workaround if oyu don’t feel like converting then flipping back is to bind a hotkey to show/hide subds. Don’t use the one in the hotkey editor; use the MEL command it calls up when you do it through the panel menu. Can’t recall what it is;though when I get home I’ll post it..
hehe..i freehand to…but judging by this model…it looks as is it was freehanded, no image planes or even a sketch first. Nothing wrong with freehanding, just an observation.
