My website and work
Please critique both my website and work. Thank you.
The website is not complete, but most of my work is up, it is best viewed at 1280x1024, let me know if that is too high.
http://www.bluehorizon3d.com/pindex.htm
At some point I hope to use the same basic design but with a Flash interface.
I like it, I think it has a nice design and a clear layout. The only thing that annoys me is that you have to place the mouse over the different sections to find out what’s in them. Wouldn’t it be better to replace “view” with the name of the section instead?
Also, I have one question. Why do you want a Flash interface instead? I think flash is overused. It definitely has its place, but your site works great in html so why switch to flash which is not as supported as straight html and css?
Also mekt the images themselves clickable! I mean its anoying to push the text whhen the image is what also could do th etrick… Just adds some tought to the inetrface.
But i dont especilay like the fact that people use flash for their sites. Because not all computers can view them. And its not astandard. But looks fresh.
Thanks for the tips guys, I’d be happy to forget about doing it in Flash since that means less time farting around with this website business. It won’t be hard to make the changes you all suggested so I will probably get around to that in a bit.
Any comments on the work at the site will be appreciated. Most of the game models in the second gallery are crap, I know, but, go ahead and critique the rest of it!!
Why is the big deal about flash? When was the last time you were on a computer without a flash player? What is this constant resistance, will it ever end? I don’t understand why even digital and motion artists are so resistant to motion on the web? The same people who bitch about size and things not loading quickly are the ones posting 20mb quicktimes that never work! What audience are you trying to reach that refuses to have flash on their computer? Just concerned about the hypocrisy.
I personally like Flash, I just don’t have time for it right now. I have a 56K connection at the moment and haven’t found reason to waste 2 hours uploading my 20+ meg quicktime files, that work I assure you.
If you can tell me how to get a 45 second animation with 16 bit stereo sound on the internet at less than 20 megs I’d be happy to hear it. But with the tools I have it’s not possible.
Flash isn’t all good anyways, websites made with Flash tend to be contrived and annoying with needlessly complicated and often times cryptic interfaces. It’s rare that you see a flash site done well to be honest.
I wasn’t referring to your site when I mentioned the oversized quicktimes. Your site is well put together, and the work is of high quality. I was generalizing. 20 mb isn’t even so bad.
With Discreet Cleaner 6, set your compression settings to streaming quicktime. 320x240, Spacial Quality 60, Quality 5, you can make a full compression 3 minute video under 10mb.
I’m not sure what you are referring to regarding flash’s contrived nature. That is in the hands of the maker, not the software. You can arrange elements in flash the same as you would a website. What is the difference between using animated gif rollovers and a flash button rollover? Not much.
I agree with all the comments above about clickable images and clearer text labels.
I would add that you might consider rethinking the layout of the galleries… each piece has a title and a ‘view’ button, but the view button is actually closer to the title of the next image down, so it’s a little ambiguous and confusing.
Overall the site looks great, though… I especially like the drop-down ‘more about this image’ boxes. Clean interface with more information available at the viewer’s discretion, not being forced on them. Good stuff.
On an unrelated note… I am hypnotized by your ‘Electrolady’ image. Could you post a larger version, and/or tell us a little more about it?
Good work, thanks for sharing.
-Steve
I don’t want to turn this into a flash flamewar so I will try to keep this as diplomatic and to the point as I can.
I have three main objections to flash.
  1. As BH3Dmod said, it is often misused. Often it just makes the interface more confusing. I agree that this is the hand of the maker, not the software, but it seems flash invites people to create dazzling sites without logic.
  2. It limits accessibility for visually disabled people. Maybe this is not a large issue when you as an artist want to show off your work since visually disabled are likely not your target audience. It is however a concern when corporations have flash only web sites.
  3. I’m a supporter of free software and standards (not a zealot, which would be hard considering the availability of open 3d tools, but I try to use free software) and flash is not standardized. At least it is an open format, which is good.
As for your comment that you can do the same things in flash that you can in html: If you have a working html site, why would you then want to migrate it to flash? I’m honestly curious about this.
Sorry BH3Dmod, for turning this into a discussion about flash.
  • Henrik
some other + for html. You could read them with a pda or talephone (remeber because theese devices have much less computing power you should do xhtml ie close your tags! also makes parsing faster on newer comps), you cloudnt do that on flash. I read web pages on my phone all the time (i even have a ssh connection on my phone so read the 4 comment!!!).
Secondly you could use a text only browser to find some textual information that you need like telephone number.
Third you could use some new or obscure computeer to view the page quite easily without a hustle.
forth, you could make small important changes quite quickly over a ssh or telnet connection if need be, form wherever.
fifth you could quite cheaply (read free, work offcourse) make your site xml parsed to html wich would allow you to make printer fiendly versions on fly etcc etc…
more easy to index and find with search eingenes. But yeah they are working on it!
The limits are endless. But yeah i would like to se svg more adopted because its beter than flash in many regards.
im not realy a anti flash person but is seems vaguely out of context 95% of the time. But hey they could make the css2 standard a bit better. Also eyecandy like rollovers etc are largely over empathized. Its the content that counts.
Sorry hampants for jumping on you, thanks for the discreet cleaner tip.
The electrolady image was made in Illustrator using the gradient mesh tool with a little bit of extra work done in photoshop to give it some color. I had a short stint one summer about 3 years ago at a publication services company doing boring work for textbooks. The good thing was I learned Illustrator, and I learned to like it. I did “Electrolady” then I started the other piece called “Erin” but I never finished that one for some reason…
At the time I wrote a very strange “tutorial” on using Illustrator that is probably the most abstract and just plain weird piece of information you will ever find on a technical subject. If anyone wants it I can send it to them.
Illustrator is surprisingly powerful IMO, I did the website design almost entirely in Illustrator as well. You can use Illustrator to create curves for use in Max or Maya as well. Illustrator’s curve control is actually better than Maya’s I think.
By the way, anyone here used Illustrator CS yet?
Well i dont find cs that much better than 10 but its nice. Well the curve tools in illustrator are not realy more powarfull than mayas its just that they are beziers and not nurbs (by the way maya can do beziers as well), the olny problem with beziers is that they do tend to wase a lot of memory compared to a nurbs chain (its like having a bunch of constrained 1 span cubic curves chained togeteher!). Aslo one reason seem to be that most users get exposed to beziers first and converting mindset takes time. But i find with little practice that working on nurbs is infinitely faster in many many tasks.
