QUOTE(mrwolfy @ 06/30/09, 04:35 PM) [snapback]310479[/snapback]
Any thoughts? Will this be efficient?
Depends on how bandwidth hungry your scenes are. And what your running now. My computers run pretty fast 4-6 drive raid5 decks and the 2Xgig etherenet (one dedicated for master disk channels) makes transfer pretty much transparent. But if i would need to 1 disks speed id get a fit. But you might not notice anything, it depends on what your used to.
On Raid 0 a likstation dual would be pretty fast tough. But also a BIT TOO risky. So if I were you id go for the likstation - quad. Which basically represents the internal disk setup i have on my personal computers. (the salave is basically with 6 disks while what i use is 4 ones. + each one has a boot disk, because idiotic windows cant boot form disks with capacity over 3 gigs)
Tough i am looking into upgrading theese things to intel SSD drives soon. The performance boost would be insane.
More than this get a external mirroring server somewhere outside your home/office. So you will not likely loose data ever again. Its a drag and costs more than one could imagine.
