I got problem to make Zdeph function in SHAKE software
ALready try in AE and Combustion all work good
but try apply same technic in SHAKE, still not working and can't find
proper tool to do it... waaaa
help
help
Look through the Shake PDF docs... they provide an abundance of information. I know the ZDepth is addressed there.
bro, iam already read previous topic about z-depth... but still dont understand...
waaaaaa....
ok, i got 1 plain image with zdepth (mean RGBAZ)
in AE can make and adjust single image to deph of field look.....
far look more blur and near look sharp.... in single image... note multiple image...
mean this image output got zdepth function from maya render output...
waaaaaaa.....help me
i already read all tutorial in page 91 about zdepth... but this version for multilayer file.... now just doit for single file (RGBAZ)
Do you underatsnd the range of your zdepth? wich is -1/ditance to object in cm!
If the img is from Maya U've got to invert the Z-channel for shake to be able to read it. Don remember exactly how i did it (monday morning) but think here should be a tutorial on the subject
came across this link (here on Highend Networks) hope it helps you out ![]()
thk for ure help bro,
i used 1 file name TUNNEL to apply zdepth efx
got 2 layer i duplicate to make it working zdepth
1 layer i apply G-Buffer and invert
and other layer i apply Compound blur ... then select the invert channel to make it work
If you look for the MayaZ plugin in the cook book, that should give you alot of info.
