Need Help With An Ocean Wake Issue
I am sort of a newbie to Maya, but I can get an ocean wake in fluid dynamics to work. My question is this, is there a way of making a wake emitter an object rather than the sphere? I have a boat hull that is a specific shape and I would like to have that generate the dynamics, I just don't know how to make that happen. Or is there a better way to do this. Thanks in advance for the help.
Al
Create a wake then delete the wake emitter. Then select the boat and the wake fluid texture then do fluid->emit from object. You can use the dynamic relationship editor to se the emitter to emit into both the wake and foam textures( if you have a foam texture ). This allows you to have only a single emitter node where density affects the wake and heat affects the foam.
Also to make the emission smooth you may wish to set the minDistance to say 0.001 and adjust the maxDistance to a useful value( based on your scene scale ). MinDistance is like a switch... when it is non-zero we use the max distance instead of only emitting into the intersecting voxels. A large max distance can slow down the simulation, however, so keep this in mind.
Duncan
