Need Help With Constrains
So i have this object, that is rigged using constrains. Now i need to move it, translate and rotate. However when i group everything and move, the constrains do their work and some parts of this object move on different directions. How do i move it without getting this, is there any way to temporarily turn off constrains?
fo temprorary disabling use Modify->EvaluateNodes->Constraints...
if Your intent is not to turn of them temporary, but use in rigging, then use another constraint target and play with weights between them.. anyway read help on Constraints - Help's helpfully helps, u know ay
I see. OK. Thx.
