dang....i am seeing how far down the rabbit hole goes
boy..this is really getting to my head, trying to contain all this knowledge and at the same time trying to research more knowledge AND at the same time, trying to relate my knowledge back to you guys.
ok here goes, this is what i have found out so far.
Level 5 RAID: Striping with distributed parity.
Data and parity is striped across 3 or more drives. Parity is distributed to each drive. Level 5 is the most widely used RAID for servers and other highperformance storage solutions. Any single drive can fail without data loss, ie. at least two drives must fail before any data is lost.
Level 0+1 : Striping and Mirroring.
Level 0+1 combines level 0 and level 1 by mirroring a striped volume. Level 0+1 provides read and write performance very close (or equal) to level 0. Level 0+1 should not be confused with level 1+0. If there is 1 mirror set, a single drive failure will cause the whole array to become, in essence, a level 0 array. Level 0+1 requires an even number of drives and minimum 4.
Level 1+0 : Striping and Mirroring.
Level 1+0 (sometimes referred to as level 10) combines level 0 and level 1 by striping a mirrored volume. Level 1+0 has better data security than level 0+1. The reason for this is that the level 1+0 controller can take advantage of a partial mirror set, but the level 0+1 controller cannot take advantage of a partial stripe set.
i got this from tomshardware.com forums...a nice place to hangout ask for opinions.
ok, Russell,
i took a look at that set up u showed me and boy is it sweet, however 1) i dont think i need so much space (as in 4 200gb drives LOL) 2) my tower can only accomodate 3 Hard Drives.
The ATA adapter card that i saw was a bit too expensive for me at the moment. i mean it looks good but i think the most memory i would need at this stage would be 200gb. That card u showed me supports up to 8 drives (4 ports). i only need 2 - 3 drives if necessary (explained further below). I saw some nice ADAPTEC cards for like 70-100 bucks, looks like that is what i might need. it has 2 ports (is that the same as channels?) and can support RAID 0,1,0/1.
So i think that i am taking your advice (and bacon's) to get it mirrored. so it looks like i will be getting 2x200gb drives. now this is where it gets kinda tricky.
WLXI recommended that i get teh MAXTOR ATA133 drives as they are a bit faster than the regular ATA100 drives taht you were suggesting. However, i do not see any ATA133 RAID cards out there (i havent found any...if they are please help me out).
If i was to go with this system, would i have to make WIN2K pro do the raid setup for me as opposed to the RAID card doing the work, sparing some of the processor work? One system seems faster (the ATA133 setup) however, is it really that much faster if the processors onboard need to do most of the work for the RAID internal setup?? ( i remember russell, that you recommend that I use hardware RAID as opposed to software RAID, but in this case would it work??).
My next question is, if it was to only get 2 drives, i suspect the best RAID setup is the RAID 1 setup, where i could mirror my drive. however, this isnt as fast as the RAID 0 is terms of read and write. can i set up a RAID 1+0 (or RAID 10) with only 2 drives? they say that the RAID 1+0 is almost as fast as the RAID 0, but has the advantage of the redundancy.
it gets worse......
currently i have a 60 gb HD in my tower. When implementing this new memory system, should i remove it completely? would it make sense to get a third 200 GB drive (to replace the 60 gb) and set up a RAID 5 or RAID 1+0? also, this 60gb drive is FAT32! the reason that i did it this way was so that i could also play a lot of my games (huge gaming fan). some games wont work too well on the NTFS system, but work great using FAT32 on WIN2k pro!
WHAT PARTITION TYPE SHOULD THIS NEW MEMORY SETUP BE? i have a feeling that it should be NTFS only because i read somewhere that win2k pro can only handle FAT32 partitions up to 30-36gb or something like that if WIN2k pro is used to format the disk. (i hear that if i used win98 to partition a drive, then it could be any capacity i wanted).
should i completely remove the 60gb and boot from the RAID? what are the implications of booting from a RAID setup?
WLXI - i saw those kits and they look awesome man, but why wold u need to buy 2 of those kits? couldnt u just buy 1 kit and 1 200 gb drive? woldnt that work? your comments are also appreciated.
