So, I am using the "Extrude Face" tool and the Y direction seems to be messing up. For instance, let's say I were to make a spaceship with wings out of a normal polygon cube. Well, obviously I would want those wings to be symetrical so when I use the "Extrude Face" tool I make sure that I select TWO opposite faces on the cube. So, I select two faces, choose "extrude Face" and start extruding. Well when I extrude in the X or Z direction BOTH SIDES move in the direction that I am pulling or pushing. However, when I go in the Y direction I PULL ONE WAY and the other selected face goes in the COMPLETELY INVERSE DIRECTION. I know the answer to this is something simple b/c I've had it happen before...only before I was in a classroom and could ask a prof how to fix it. Anybody know what needs tweaking?
