Need realistic *fluid* ocean simulation (2)
I've taken on a project I thought would be quite simple given Maya 5.0's Create Ocean options, but have found new difficulties.
I need an ocean surface that can be influenced by fields so that I can simulate crosswinds; a shallow "water dome" phenomenon called a gyre; and ocean water traveling in a broad circular motion around the gyre.
I don't think this is possible with the Nurbs plane with the ocean shader, but I'm not experienced enough to create a realistic ocean using fluid effects.
Any suggestions will be most appreciated.
PS I've browsed the tutorial links, but there's maddeningly many of them, and half the links don't work.
