Hi all,
This is too advanced for my MEL knowledge. But I am trying to make a "slider" attribute in the channel box or a separate window for the following command. ________________________ performPolyAverageVertex 0; ________________________ Reason why is because I am trying to do an interactive ability to tighten my verticies. I wanted the scale to go from 1-10 with 10 being the maximum pull.
Would this take a long time to do? Is it possible?
Thanks in advance,
Phil
I don't think this is at all possible to do with that command. Another method to try would be to turn on History and run that command once. Now it will show up in your history and if you click on it, I think you can change the values and see the result. (don't know for sure, I havent tried it). I wish Maya offored more interactivity too.
In reply to: Hi all,
Thanks in advance,
Phil
Morris Olmsted 3D Designer @ Idol Minds LLC molmsted@idolminds.com
Thanks for the reply. Guess I'll just have to use Mirai for the meantime. This tool would be the coolest thing since sliced bread if it were embedded as a Maya tool.
In that vein does Maya have anything similar to lightwave's bandsaw? (Plane Belt Selection/Devision)
Don't know, I've never used Lightwave. But there is a drawSplit tool for Maya.
In reply to: In that vein does Maya have anything similar to lightwave's bandsaw? (Plane Belt Selection/Devision)
[quote] In reply to: Thanks for the reply. Guess I'll just have to use Mirai for the meantime. This tool would be the coolest thing since sliced bread if it were embedded as a Maya tool.
[/quote]
tnt
July 13, 2001, 5:08pm
6
here is what you want:
//********************************************** string $pa_result[] = polyAverageVertex -i 0;
window averageVtxWindow; string $form01 = formLayout; string $button01 = button -l "update"; string $slider01 = intSlider -min 0 -max 10; setParent ..;
formLayout -e -af $button01 "top" 0 -af $button01 "left" 0
-af $slider01 "top" 0 -ac $slider01 "left" 0 $button01 -af $slider01 "right" 0 $form01; window -e -h 48 -w 220 averageVtxWindow; eval ("button -e -c ("updateVtxSlider " + $slider01 + "") " + $button01); eval ("intSlider -e -s 1 -dc ("averageVtxSliderCommand " + $pa_result[0] + " " + $slider01 + "") " + $slider01);
showWindow averageVtxWindow;
global proc averageVtxSliderCommand(string $attrName, string $sliderName) { int $value = intSlider -q -v $sliderName; setAttr ($attrName + ".iterations") $value; }
global proc updateVtxSlider(string $sliderName) { string $pa_result[] = polyAverageVertex -i 0; intSlider -e -v 0 $sliderName; eval ("intSlider -e -s 1 -dc ("averageVtxSliderCommand " + $pa_result[0] + " " + $sliderName + "") " + $sliderName); } //**********************************************
this slider goes from 0 to 10. The update button resets the slider and uses the current selection for a new polyAverageVertex-command
enjoy
Thanks in advance,
Phil
Holy $#!T.... all I can do for now is say "Thank you".
Stefan, you friggin Rock. You don't know how many people I know who can use this script. I'll be sure to let them know who made it. =)
Hello Phil,
polyAverageVertex already has an interactive slider? As does most Maya attributes if you create them with history.
under polyAverageVertex highlight "Iterations" and MMB drag in a view panel to interactively change the value.
mmb attribute interactivity is uber-powerful without a lot of gui clutter
If you need more sensitivity to the slider, hold down the control key while mmb dragging
In reply to: Hello Phil,
Thanks for the tip Clay. Everytime I do a modeling function now, I am going into the channel box and MMB+drag everything to see what and what isnt interactive lol!
