Need Some Critiques About Mapy
Hi every one. I wrote a tool named "mapy" few weeks ago and it works well on my pipeline.
Then I shared it on highend and Thanks all for using it. BUT I havn't gotten any reviews about my software AT ALL. mapy is an external commander that let you use every editor with maya.
I wrote it because I love mel studio but it is limited. You can use mapy With your favorite editor and exiting thing is when you select some lines of code in your editor, and push a hotkey, mapy only sends that lines of code automaticly. exactly like maya script editor and mel studio. you can use it with SciTE,
Notepad++, Textpad, ... And it also shows you maya's output in your editor's output.
I ask you to review my tool and give me your wishes about mapy.
http://www.highend3d.com/f/mapy
Thanks in advance, Farsheed.
Well theres nothing very special about sending data to a command port, in fact you can use many other free programs to do this. Internet is full of them... hell most systems have them installed by default.
Theres like i posted in the comments section a huge Caveat for this. Its VERY very dangerous, since maya now responds to that port, winch makes hijacking your computer much much easier so be sure to PROTECT your ports in your firewall. And please let the user specify the port so no one knows what it is, if they can bypass to alowevr level user right on the computer. And like is said thsi makes pranksters on the workplace LOVE you.
In a sense theres nothing special about this, ive used the command port for this as far back as in maya 3. But yes you need to be carefull about the permissions since it IS dangerous.
If you can pass that and the limitation in amount of data the port can handle then ist okay. Like i said i use more or less the same thing so...
Thanks Joojaa, Next version I'll add customizing to mapy.
