Hi there,
I am trying to create an expression that will cause an object to move negatively from another.
For example, if the reference object moves in X positive axis, then the object with expression moves in X negative axis.
But I don't know how to write the right syntax. In the Expression case (in Expression > Edit), after the dot, what do I type? There is no "negative" function curve in the list (when clicking Fcurve).
Any help is appreciated
Thanks
Bernard Lebel
