New images and stuff
Hi all,
Heres a link to my temporary website. see what you think
Cheers
www.geocities.com/kwasind2002/home.htm
KnickKnack
your train, tunnel and lego.avi’s do not work
the images are petty cool, nice work!
sure would like to see more of that!
www.dotblend.com
hey, that house is from a “explosion tutorial”… you just textured it.
but other than that, good work…
[edit]: sorry for accusing you, but the houses are extremely similar…
actually, I think you’ll find I modelled it myself; any similarities between my work and other models are purely coincidental. I’d like to know which tutorial you are referring to?
KnickKnack
Really nice stuff.
A couple of things to look at:
  1. Try to make flat surfaces not so perfectly flat. For instance, the roof on the farm house has some inperfections, but the fire place is extremely square and sharp looking. The cart being pulled by the tractor has a similar problem. The fence too.
  2. The porch roof on the farm house doesn’t look like it has enough support to withstand such a long span. Perhaps add some joists, or maybe another pillar in the middle (if it doesn’t effect compostion).
  3. The bird looks a little “shiney”. Turn down the specular or maybe change the specular highlight color to be a little darker.
  4. I like the farmer’s design, but he looks pretty strong and healthy. From the story board, it implies he dies because he misses his wife. However, I can’t imagine this character doing that. Perhaps the farmer needs to look older, or maybe he could commit suicide. You don’t have to make it graphic. The sound of a gun shot is more than enough. Just a thought.
By the way, I really like the farm house. Someone commented the model looked similar to a lab someplace, but that you textured it. We’ll the texture is what makes it look so nice anyway. Besides, you have enough work on your site to see that you don’t need to “barrow” stuff, so I believe you.
Urp
Thanks for your comments and critique Urp, much appreciated. You are right about the flatness of the fireplace. Im also a bit unhappy with the porch roof. I will make it bend inwards slightly and, as you say, add sum struts to give it more support.
The farmer does look quite healthy, but im going to make him stoop, give him a more solemn look and hopefully express a haggard look on his face. I do like the shotgun Idea, but I prefer the thought of him just letting go (a voice in the film will tell him to do so, almost like a whisper in the wind).
I’ve toned the specular map down on the bird so it doesn’t look so plastic. Thanks.
About the farmhouse. That’s really jarred me; I can’t stress enough the authenticity of my work; it’s all mine, I modelled it, I textured it, I animated it. Any similarities to other work is of pure coincidence.
Thanks again Urp
KnickKnack
I thought of something that might be useful.
To help show the contrast after his wife dies you could make the farm house look run down. Weeds growing all over everything. The house loosk older, less kept up. etc. Perhaps lots of flowers and land scaping while she is alive, then later nothing growing around the house…like it is dead too. Maybe some cheeful song birds in the scene. Then they are replaced by the ones you have now.
Just a thought. Perhaps you were planning on elements like this anyway.
Again, nice job. I look forward to seeing your project develope.
Urp
I gotta agree with XGC…that farmhouse looks suspiciously like someone else’s, however I shall give you the benefit of the doubt.
I like the modelling work on the human character at the bottom of the images section. Really nice. I would like to see it animated.
As for the animations, I can’t see most of em cos the website keeps reaching its download limit, anways, I did watch a couple of em. As far as your ball animation goes, this is typical of amature work on a basic levgel. I don’t mean this in a patronising way, but as an experienced animator at many of the top production companies around, there a certain things that I would mention to you so that you get used to a certain way of thinking.
Firstly, the typical thing that early users of 3d animation do is to pick up some cool plugin that they think none of their fellow students have so that they look well cool for doing an effect that the other students think required talent to produce. Thats not to say you aren’t talented, I think you clearly are and have a lot of potential indeed. However, if you are going to use some plugin like Aretes Digital Nature Tools (which your ball animation looks cunningly like) it is wise to apply it to your abilities and not just switch it on and say hey wow. I.e. your ball has been plonked in the middle of a default ripple to suggest that the ball is making that ripple. I think you would find that such a ball, light, plastic, floating in a lake / ocean type situation is very unlikely to form such bulbous ripples like that, if any. The motion of the ocean should determine the adverse effect the ball has upon its surroundings. I.e. still water would ripple smaller ripples than the one you used at a faster rate, if dropped from a height. If the ball was just floating there being blown by a gentle breaze, it may give off ripples at a lower frequency at less intervals, as well as a directional wake. In a rougher sea like yours, the ball is being affected by the water, it should not have the power to send such large ripples if any through water so powerful that it makes the ball bob ike that. Seems basic I know, but its the very rock bottom basics you need to understand and constantly bare in mind to make more complex animations and characters truely come to life. You need to really pay attention to physical realities and fine detail.
~Pootang~
what rendering u r using?
Hey knick I think the farmhouse they’re reffering to is on
http://www.mtmckinley.net/
He did a similar looking barn, one he modeled from a picture he took, however similar they may be, they are quite two distinct pieces.
Everyone should keep in mind that all old barns and houses built on farms out west were all built the same way. The idea was to have a main crossbeam in the middle, giving it a triangle look, and usually a tiled or wooden roof, and later on aluminum. Give knickknack a break, his project’s turning out to be quite unique and interesting. I can’t wait to see the final piece. Keep up the good work!
Get off KnickKnack’s back man, the house is strong same as the rest. Why would he be arsed to texture someone elses work. I know the guy and he’s not the colouring book type.
I can’t believe the amount of flak i’ve recieved from that damn barn. Once and for all, it’s mine. I modelled it. As -dc- pointed out, most barns look the same. How many styles of old barn do you americans have?
And Pootang? I know you didn’t mean to sound condecending and patronising, but you were. I’ve had criticism that has been constructive from Urp and I thank him for it. Accusing me of using a digital nature plug in for something when you have no firm proof of that again seems quite harsh, and also unprofessional. I used 3D studio max, with no plug-ins at all. My own shader for the water, and the use of the noise and ripple modifiers. Simple, maybe, but all my own work and choice. Im trying to show an understanding of realism, realistic water movements, realistic lighting and texturing; why the hell would I bother showing work I created with a plug-in tool that did it all for me?
It’s the last time I post work on here; the whole thing has left me with a bitter aftertaste.
KnickKnack
ahem, excuse me, nothing to see here…
Please, if you will. Mr KnickKnack happens to be one
of my colleagues. I have seen his project develop
from day one, storyboards et al.
As a fellow Artist, It has to be said, there is a lot of, if you would excuse my francais, ‘Guff’ that happens with
3D animation. I am experienced with the perception of
such ‘guff.’ I know for an absolute fact, that Mr KnickKnack has built all his models from absolute scratch, polygons, the root of all 3D. I have seen the blood, sweat and tears of this man, have experienced his wrath, and have seen his modelling genius. His is
not, I repeat NOT a lazy ****. He puts in the hours.
To those who dont, you bring down the rest of us.
Keep 3D real people, keep it fresh and clean.
Dont get bogged down by whats been done. Invent, and develop your style, as this is the essence of good
work.
Bon chance mon amis.
"It’s the last time I post work on here; the whole thing has left me with a bitter aftertaste. "
I honestly think you should reconsider.
I think your work showed very well. There is always going to be posts from people who don’t give a rats behind if they are helpful or not, but the plus side is that you get to hear opinions from those that do want to help. I for one had no idea you had developed so far.
What I think is ironic, is that some work that is very “average” get’s nothing but praise some days, and the next day people are ragging the work of masters like Final Fantasy.
Keep up the good work. Don’t let other opinions make you lose focus.
Urp
I also think you should reconsider, your work is great…you have good modeling skills. I haven’t seen your animations yet but it’s obvious you can model and storyboard so keep up the good work. I’d like to see more. Oh and my only crit is your still with the crow on the rock…it looks like it’s floating just above the rock. That’s all I can say…the farm stuff looks great.
post deleted
Don’t stop posting. To survive as commercial artists we all need harsh criticism as well as praise. We can’t afford bruised egos. Take what you can from it and let the rest roll off your back.
I agree with Pootang about the ripple. CG is all about the look of the thing and you’ve created something that looks as though it was created with a plugin with some default settings. If this work is intended to be put on a demo reel to be sent to potential employers, keep in mind that if they think you’ve used a plugin, they won’t write you a letter about it… they’ll simply throw your reel in the trash, no questions asked. And then all your hard work will have been for nothing. It’s a harsh truth but it’s just that–truth. For my part, I’d be grateful to receive criticism of the level Pootang offered. If I want someone to ooh and ahh un-critically over my work, that’s what family is for. When I need useful feedback… I’ll go find the most crotchety, critical, ill-tempered and impatient old 3D pro I know, and suck it all up!
As for my own criticism… the modelling of your farmer character is wonderful, especially the clothing. But I have a problem with the character design of the face. you’ve chosen the features that traditionally appear on a villain: hooked nose, prominent chin, low protruding brow, leering mouth. I think it’s going to be tough getting him to come across as the sensitive quiet character that your storyboard calls for. Remember, that final shot will be all-important, so you need a face that will look peaceful and serene; as it stands I think he will look pretty macabre as a corpse.
Great stuff, looking forward to seeing the film. If you have any questions or comments about what I’ve said, feel free to message me. Thanks for sharing your work.
-Steve
Thanks Urp and Steve for your comments. It’s not criticism I can’t take, it’s accusations of theft. I take your point about the ball in the water. I did spend quite a while on it (you’ll notice the water casts a caustic effect on the balls underside, achieved with a spotlight and a custom made water animation projected upwards) but it does come off as a simple plug-in effect, I admit. I just wanted to show little snippets of a variety of things that showed I was competent at all sides of CG, including gimmicky special effects. Pootang just came across as someone who’d immediately compartmentalised my work as ‘another student demo’ which contained a by-the-numbers and typically cliched arrangement of shoddy, plug-in effects, and when you’ve spent the best part of nine months producing the best work you’ve ever done, it’s hard to say “yeah, thanks for that ‘crit’, I’ll take it all on board”.
At the moment, I’ve gotta finish my work by June 10th or I fail my degree, I’ve got an interview on Friday at a games company, so im rushing about like a blue arse fly trying to find the life drawings I did four years ago, while trying to put together a portfolio of my “plug-ins” and “copied” work to show a prospective employee.
I know most people on highend are good natured and help whenever they can, but man, some people really annoy me, and I’ll defend my work if I think im being unfairly treated.
Anyway, I’ve moaned long enough. Steve, you may be right about the old farmers face. Im trying to go for a haggard and worn out look, and Im currently texturing his face, but he might end up looking like a psychopathic quasi-autistic cross-dresser, it really is straight down the line.
Thanks again,
KnickKnack
Wow, that was an interesting read
Im another uk student and am so glad i found this website tonight. Im doing an animation for the menu on a dvd im creating in New York this summer, im still in my sketchbook and have lots to do, but looking at your work has sure raised my standards for what ill settle for. Your storyboards are art all by themselves (very good), im at Manchester doing art direction, i hate it so ive turned my hobbie of 3d animation and my job Ive got this summer into a self directed project.
Im definatelty going to put it all up on the internet for a crit, but its going to be nowhere near as good as yours, id just like some helpful? comments.
What uni are you at and where are you applying for a job ?, my friend has just got a job a year ago at Lionhead, he’s got some contacts there. Email me Stevenhanton@aol.com
Fair enough, man.
I remember looking at the caustics on that ball and thinking they were gorgeous. So great work there.
As for the farmer’s face… I get what you’re going for. Try pulling parts of his face down, especially the corners of the eyes and mouth. It will make him seem more haggard and sad, less predatory and leery. If you pull the brow up in the middle so he’s got a sort of permanent woeful look, that would also go nicely with the character…
Good luck on your school and your job interview!
Hey, I’ve got some life drawing work handy, want to borrow it and pass it off as your own? --I don’t mind…
j/k j/k j/k j/k j/k j/k!!
If your drawing is up to the standards of your CG work then it’s stuff to be proud of.
-Steve
