New SGI NT workstations
I took a look at the new SGI workstations, don’t you think the old ones were a little bit more revolutionary? They even took off the 64bit PCI slots. I’m the proud owner of a SGI 320 and I got the impression I got better equipment. I may need a little more info on the new Vpro graphics system.
Any reactions?
Oh.. I almost forgot.. When will SGI use the Itanium 64 in their machines?
I agree, I got more for the price than the new ones (at least here in switzerland the new ones are higher priced, with less memory, cpus, disk etc…)The only point is, the old ones uses special ram and cpu modules, which are very expensive, I also don’t know if you can upgrade the 320 with wildcat or V graphics. Could be difficult. There will be probably no cpu upgrades for the 320. would like to smash in two 800 Mhz chips…
I think the power of the new ones,
is in the Nvidia graphics chips.
the old cobalt did not perform very well,
and the nvidia chips are pretty amazing.
-Tad
Tomi@tad3d.com
http://www.tad3d.comhttp://www.tad3d.com
Noe,
You are correct about upgrading the graphics. The 320/540 has the graphics sub system integrated into the mother board. There is no way to dissable the Cobalt graphics inorder to upgrade to a new graphics card.
Urp
I am pretty satisfied with cobalt, it delivers about the power of high impact graphics, maybe a little bit more. And if I can handle a 300mb architectural file interactive in shading mode, (I do so now) thats enough I think. That’s already lot of work for this little black chips. I wouldn’t have to calculate this by hand…How long until we do not need to render final pictures ??? I need this breaks with my coffee cup, gives time to look out in the green, playing with juggle balls …
just realized they took off the firewire too - what a shame.
Maya rocks, FinalCutPro rocks, Firewire rocks…
  • I know It’s not highend, sorry do not have the money to buy digibeta. So firewire and dv is a perfect solution to do most of my work. I can’t understand why built in firewire is still not standard on good pc’s. Apple Machines have it since end '98, no setups, no configurations, no troubles, just plug in your deck or camera - video has never been so easy to use before.
“fire wire” or 1394 is not a standard on pc’s because of the absorbatant royalties that the dumbasses at Apple wanted for the use of it. Now they dropped it(much lower) and you can now get it standard onboard on quite a few mother boards or you can just buy the pci adapter for it just like adding a scsi card. Fire wire costs no more to manufacture onto a motherboard than a com or paralell port butr it was political Mac bullshit(typical) that has kept this standard from developening much faster than it has. 1394 is great. asus, gigabyte and a few others have onboard 1394 but I would much rather get a pci card so you can take it with you through all system upgrades and enhancements
“I put my faith in the power of my own mind.”
ICQ#58898276
The royalty issue is a common misconception and had little to do with anything, although much was made of it in the press (funny that). Many factors were in play.
USB cannibalised 1394 potential markets. Peripherals migrated from SCSI and parallel to USB not 1394.
This caused a dearth of devices and OEMs saw no need to support a niche market.
It is the cost of the chipset that hardware manufacturers balked at (around $40-$50 for both physical layer and link layer) and the slow adoption under NT. Unfortunatly MS misread the market, it was professionals “making do” with firewire not consumers (win98) that drove the early adoption.
MS is now a big 1394 advocate and expect them to push it hard.
Sony are fighting with the MPAA to make this the DV standard for HDTV (they recently pulled their entire line of new HDTV models, 1394 equipped).
There are only a few days to go before the 1394 trade annual conference at which 1394b spec (800 - 3200Mb/s) is slated for release, as well as lower chipset costs (@$7 per port).
This faster spec will finally satisfy the high end of the video market, so expect to see more happening there.
It will also take a serious run at SCSI on the desktop.
