New To Maya - Import Wavefront Obj
Hi,
I'm only new to Maya, and have only dabbled in 3D software. Most of my work is in e-Frontier's Poser 6 and 7, whilst modeling is mostly in Blender 3D. I recently downloaded Maya 8.5 PLE - hey, it was free - but am finding it a bit of a steep learning curve so far - almost steeper than Blender, and that's saying a lot.
I would like to import Wavefront obj files to manipulate, and came across this link - it appears to be a mel script, which according to KillaMike718 goes into the C:\Documents and Settings\Charlotte\My Documents\Maya\Scripts folder:
QUOTE
... if you want to install the plugin, you have to first find your two important directories:
1: Program files > Alias(Autodesk for 8.0?) > Maya (x.x = Version) > Bin > Plug-In
2: My documents > Maya > Scripts
Those are where the plugins go.
But for this plug-in, all you need to do is place the file in your scripts file and the icon, goes in (My documents > Maya > Prefs > Icon)
...but this isn't a plugin, right? It's a script, like a Python script except written in mel, whatever that is.
The post I was reading was refering to exporting an obj file - I'd like to import an obj file. Anyone have any simple ways of doing this?
What I find interesting about this whole thing is that I decided to try Maya because of its history with the Wavefront obj format... and find it curious there is no native support for that format now.
Cheers,
Charlotte
QUOTE(Charlottesv @ 10/07/07, 08:33 AM) [snapback]274448[/snapback]
It has support for obj natively, maya just dont load that and plenty of other module on startup unless you enable it first! Because they do slow things and if you dont happen to need them then. To load a plugin down open up Window->Settings/Preferences->Plug-in Manager and tell maya what you need by default.
Ofcourse the ple has NO export possibilities, because thats the point of it. Its so you can use maya for learning not to make assets to anything. Also ple has no support for fwrites or reads either. So any file accessing mel is out of the question.
PS: you could start up being pro right now and search the help first. It has clear instructions on stuff like this. (i still haven't seen a software that costs money that DONT ship with a manual on windows that dont launch form f1)
For example about obj import/export (im using autodesks online version of the manual here):
http://download.autodesk.com/us/maya/2008h...le\_formats.html
G'day!
Thank you for your response. I'd like to clarify that my resorting to this forum was well down the line of steps in my research - I did find the online help, and searched it thoroughly, but it was a case of "you can do that" without the 'how'. I'm sorry I'm a bit of a dummy - I need a bit of direction. In the Linux world (Ubuntu) people generously point newbies like me to the right resources, encouraging me to "keep trying, you'll get it eventually". I guess I kinda got used to that generous attitude.
Believe it or not, I had already found the Plugin manager. Enabled plugins are the following:
compositingInterop.mll
fbxmaya.mll
ik2Bsolver.mll
ikspringSolver.mll
Mayatomr.mll
rotateHelper.mll
studioImport.mll
VectorRender.mll
No idea what these suckers do, or where to find info on them. I have looked in the manual. Searched on Wavefront and obj, and I got Wavefront (obj) export plugin - I don't want to export, I want to import. I thought I made that clear.
The enabled plugins have enabled Info buttons, none of which give any clue as to what they actually do, and there is no way of knowing what the other non-enabled plugins do. The page you sent me tells me that Maya2008 natively supports obj files. It doesn't tell me that Maya 8.5 ple does. I didn't say I wanted to export obj files, but rather import them. However, from what you are saying,
QUOTE(Joojaa @ 10/07/07, 11:02 PM) [snapback]274451[/snapback]
...mel scripts won't run?
Also:
How? Which plugin? Or, how do I know what the plugins do?
Again, how? Which plugin? Or, how do I know what the plugins do?
I'm afraid that statement left me puzzled. What do you mean by "not to make assets to anything"?
[b]PS:[/b] you could start up being pro right now and search the help first. It has clear instructions on stuff like this.
I did search the help first and the instructions are very unclear as to importing Wavefront obj files.
Maya 8.5 ple was free.
http://download.autodesk.com/us/maya/2008h...lp.htm?context= General&file=Supported_file_formats.html]http://download.autodesk.com/us/maya/2008h...le_formats.html
You obviously have Maya2008 - I have Maya 8.5 ple. I'm not going to assume that the help files for a freeware version of an expensive 3D package like Maya are going to contain the same instructions as the full pay version you are enjoying, since the freeware version will probably be missing some features. Quite possibly the ability to import obj files could be one of them.
Thanks again for taking the time to consider my problem and for your response.
Cheers,
Charlotte
Mayas harder because it is basically a academic development program, and assumes you have a degree in some science or art.
Its aimed for people who know in general what they are doing. And this is one reason why certain people avoid using something like max or Microsoft office. Where its assumed
that the creators of the software know more than you do about what you want.
Off course its not nice for beginners, but if you always target beginners you will have a lot of users that resent it.
QUOTE(Charlottesv @ 10/08/07, 01:55 PM) [snapback]274498[/snapback]
Yes but it is based on 8000$ program, and its essentially the same software without any possibilities to save out anything except maya ple locked encrypted format.
Oh, sorry my bad. Yes it appears thet ple does nolonger ship with the obj reader, in ple 8.5 (they used to not read anything in). Normal maya does and thats essentially it, its free and you get what you get. Convert the obj file to a collada file (dae).
thus leads to:
QUOTE
That means theres no way to use maya ple to save anything out of it. You can save into a properitary mp format that is eassentially a crypted maya binary file. And that file can onnly be opened by maya ple. Not even normal maya can open the files. So everything you do is landlocked.
QUOTE
click on the info button next to it once you loaded it.
QUOTE
I assume nothing i prefeer to know (I jsut wasnt in position to chek this when i worte the message). I have ple installed on several of my secondary computers around the city, just so i can troubleshoot mel outside of my home and work office (and yes i have access to 2008, as well as 4, 4.5, 5,6, 6.5, 7, 7ple, 8, 8ple, 8.5, 8.5ple in one way or another).
The ple manual is the same as the full softwares manual (except it does not contain the api, unlimited and python sections because you cant use them), which is available for free on the net. In fact the manual is so much maya that it contains allmost no ple specific stuff.
For exampla you can find that page in the shipped 8.5 ple manual by hitting f1 and pressing search. Tyope obj into the search box and click on the Supported file formats link.
Exact same page!
