Newbie in need!
I started Maya 4.5 three days ago and have gotten progressively better at producing models, but I cant find out how to texture my models with textures that I have made myself. Also How do I make shapes that are not just a bunch of modified primitive nurbs? How do I make shapes that are not a torus, cylinder, or sphere? And finally, when I am rendering how do I change the background that it renders on?
http://www.highend3d.com/boards/showflat.php?Cat=&Board=mayageneral&Number=145961&page=0&view=collapsed&sb=5&o=&fpart=http://www.highend3d.com/boards/showflat.p...p;o=&fpart=
though..thats a lot of questions there.. lets see..
first off you map textures via materials you create in the Hypershade.
Next..
you can great more complex objects a few ways, one is modifing the primitives you have already created, another is creating CVs (curves) and using surfacing tools.
Not sure what you mean by changing the background. The render if you are using a 3d bit format, should give you an alpha channel that you can use to composit anything you'd wish into the background in a program like Photoshop or After Effects.
If you want an image to be projected behind , you can use mapped geomtry or perhaps a camera image plane.
Check out the Highend Bookstore for some suggestion on helpful maya books.
http://www.highend3d.com/bookstore/?section=mayahttp://www.highend3d.com/bookstore/?section=maya
That would porbably be your best bet for some indepth instruction.
