Hey everyone, I'm currently trying to write a simple script that will change the attributes that I've added to a controller with an array but I seem to be getting the syntax wrong.
If I add a setAttr command (to make the attributes that I've made with the for loop) keyable, I seem to be getting the syntax wrong.
This is what I had:
setAttr -k on |PLC. + $name;
string $mySel[] = ls -sl;
string $name;
int $arraySize = size $mySel;
for ($i = 0; $i < $arraySize; $i++)
$name = $mySel[$i];
select -r PLC;
addAttr -ln ($name) -at double;
I know that I could just add the "-k 1" code into the addAttr command but I still need to figure out how to write the code for another part in my script.
I've tried it like
setAttr -k on |PLC.$name;
setAttr -k on |PLC.($name);
setAttr -k on |PLC. + ($name);
setAttr -k on |PLC. + \"$name\";
but seem to have no luck.
If anyone has any suggestions on what I'm doing wrong I would really appreciate the help.
Thanks in advance.
