Newbie questions..
I’m trying to learn XSI, coming from a Maya and (back in the day) Soft3.9 Background. Now, can ANYONE tell me:
-Why textures wont show up when i am in texture mode. I assign a simple checkerboard to see how my UV’s are looking, but I need to use that render region thing to see any changes.
-Number 2, how DO I edit UV’s? I can get a projection onto the cylinder, but I cant seem to bake out the UV’s or do anything to get something to come up in my texture view window.
Any help would be greatly apreciated.
Mike R
Have you selected the UV coordinates you want to use in the image node under texture projection and the texture editor under UVs ?
heyas, that’s because you are using a 3d procedural texture, which are neither displayed in the textrued mode, nor in the texture editor, because they are calculated at rendertime, afaik.
Cheers,
Balgillow
to bake textures u select the projection in the explorer view, u will find it under clusters I think and it freezes it…
Textures show fine for me and u can adjust some of their settings under the material tab… I found it useful to set up a different layout for textures so i could double click on parts of the tree and it would raise the relevant property editor.
al.
