Newbie Rigging Questions
Hi,
I
For most of the joint beside the hip, solution will be just use orient constraint and lock the translate of the controller.
for the Arm Ik, just simply parent the ik to the controller and orient contraint your hand joint to the controller.
that should do the job...
Hey thanks Pcku,
That really helps!
I think my problem was that the weight on the orient constraint tool was set to 0.
The model I'm using has a tail, where I used a spline IK with cluster controllers to handle the spline. They work fine. My only problem with it now is that when I move the waist, everything but the tail moves with it. Instead, it stretches out this bone that it created between the tail base and the hip.
I don't know where this bone came from, I didn't put it there. If it helps to know, I modeled this and skinned it in Max, then imported it over with the FBX plugin without any problems, just that the bones look a little different. I don't think that this is why I'm having this problem though.
Sunds like you want the tail clusters parentted to your hip!
