Newbie thrown into Maya problems
Hello
First...Im not sure this is the right forum to ask, but since Im newbie I felt this was the one.
Im writing a facial animation viewer, c++/openGL.
It will load a head model, mesh (neutral expression)....render it...and receive facial animation parameters...and from that, generate an expression.
I will not be blending from several pre-made expressions, even if I suspect that to generate a better result...estetically.
I want to use Maya as the program for creating these models.
Problem: I dont know Maya and Im short on time. I've already been able to parse out (from a *.ma file), vertice list, face list, edge list and texture information. But Im stuck on this
muscle/bone system...
Where can I find information on what Im really dealing with and how stuff works?...from a more technical view,
the file format....MEL scripts...etc...its very hard to parse
out all the information
Hit f1 and take a look at the pages available under devloppers guide... The sdk also comes with a few games porter examples that export into other formas, even bones.
On bones thay are just special transform matrices nothing else. Each is just relative to the next. You might want to convert theese movements to the object space of your head. For easier manipulation on your part maybe. But you cont actauly want to think of them as nything more than just individual clusters in objectsspace (cluster just owns certain pints so that they move wihen the cluster moves, but the trick is that each cluster can own parts of the transform)
