Hi,
I have only been using Nuke for a few weeks, so any help
would be greatly appreciated.
I am trying to remove the normal blue and white sky, and
replace it with a red sky on 190 frames.
I have tried Primatte, but this will Primatte the whole
image not just a section. (also wont work as the sky has white in it)
I have tried the Brazier tool, but I can’t find the right
setting to combine the 2 images and the Brazier.
http://i150.photobucket.com/albums/s91/melonrecords/nuke.jpg
As you can see, I have 2 problems, the first is the image
size of the red sky is not the same, please can someone tell me how to resize
it, as I have converted it into 2D, and then resized it, but that is not
correct.
The second issue is that the red sky is not working at the
top and to the top left? Strange?
Do I have to invert the Bezier, and what merge setting do I
need to have it on (overlay, mask, etc)
On a side note, the Bezier should not be on the red sky in
this image, as it is not connected?
http://i150.photobucket.com/albums/s91/melonrecords/nuke2.jpg
Thanks again.
Will.
